1982 evenrude 70 HP
mrjack4
It will start and has spark. It will run up rpm in neutral with the start leaver up. But when it's in gear can't get any RPS .. Any ideas
eavega
Start with basic checks. 1. Check compression on all cylinders. Compression should be fairly even across all cylinders (within 10%). 2. You say you have spark. Have you checked spark with an air-gap tester? Can it jump a 7/8 inch air gap with a bright blue/white spark? 3. Have you checked for proper functioning of your carburetors? are the butterflys opening evenly as your roll the throttle, and is the timer base moving? Will it idle after it warms up with the warmup lever down? Are you testing on muffs or in the water? If it won't rev up in the water, you could be possibly dropping a cylinder. If it won't even rev up in gear while on muffs, you could be looking at a fuel restriction, possibly a carburetor issue. Happily most carb issues can be resolved with a good cleaning/rebuild. run some tests, come back with some results, and we can better troubleshoot your problem.
Rgds
E
