I have a aq125a and am setting the dwell on it. if i set the dwell to 62 degrees while cranking, as manual says to do it. Then when i start it up and run it at 900 rpm, the dwell is at 58 degrees. is this normal.
Other problem i have is the shifter has a lot of forward play before the throttle plate moves. But when doing it in reverse it moves the throttle right away.Not sure if there is adjustment for that or not. thanks
