1982 90 hp Johnson ign issues. HELP
boat bonanza
im trying to get a 1982 90 hp Johnson running right. when I bought it, it did not have spark in one cylinder, (facing back of motor it was top right cyl) I had great compression on all cylinders (about 145 on all).first thing I noticed was that the cylinder with no spark had a piece of wire sticking out that would definatly been arching to the block if it had spark. I tore the carbs off and went through them and cleaned them up. they were clean to begin with. then after tests I determined that the switch box on the right side of the motor was why I had no spark on that one cylinder. so I replaced the switch box and I went ahead and replaced all 4 coils and all 4 spark plugs. I no had spark on all 4 cylinders but went I start it, it is very obviously out of time. doesn't sound bad at idle but reving it up its very rough and you can here it come and go. hold it at the high rpm it will rev up and down and you can here the poping. now upon further inspection after I run it like that then shut it off, I find that the left side spark plugs are still somewhat clean and slightly wet. the right side how ever (where I had to replace the switch box) the plugs were extremely carbonized (black and sooty) and dry. now I know I have fuel getting there because when I run it with just the left side plug wires on. then the plugs on the right come out wet instead of dry. and it runs a lot smoother. (just half the power obviously) but when I plug in the right side plug wires again then I start getting sputtering and poping. could this be an issue with the trigger or stator or both? I assumed since that bare wire arching to block is what would have fried the switchbox, could it also have fried or damaged that side of the trigger or stator as well? like I said I have compression, spark, fuel and the left side runs put something is up with the right side. any ideas?
Honorary Supreme Mariner
Is the orange / blue wire going to the top coil on both sides ?
toddschubert
It's kind of difficult to relate to the motor in "sides". The action of the motor is in a criss cross fashion. Are you absolutely sure the spark plug cables didn't get mixed up and miss placed somewhere along the way? This is easy to do from top to bottom.
What is the "switch box" you are referring to? Plug wires come from coils with smaller wires that come from control unit, the brains. Do you have something else in between?
switch box / powerpack / CDI / brain--------All refer to the same thing.
