I have a 1982 70hp Johnson, it has been setting for the better part of the last 5 years. I replace the fuel lines from the fuel pump to the carbs & replaced the spark plugs. I allso added Sea foam to a fresh tank of gas. It took forever to get it to start and when it did it would only run when choked. I got an inline spark tester and I have spark to all 3 cylinders but it
still seemed to be missing. I pulled the new spark plugs and it looked like the only one that had been firing was the top cylinder. I than took a spray bottle of gas/oil mixture and sprayed into the two bottom carbs while it was idling and the motor surges. When I do the same to the top cylinder the motor dies. I cleaned the fuel pump screen and there was no change. On a side note I noticed that after I had pumped the bulb on the fuel line after several hours it is soft again. Any
help or advice would be appreciated.
