1981 Johnson 115 Water Intake Screen Replacement
pbailey
I recently bought a used 1981 Johnson 115 hp<br /><br />The water intake screen is gone. I did a water pump replacement on it last weekend and while I had the lower unit off I noticed that the screen might be replacable.<br /><br />However my manual dosn't identify this part in the breakdown. The screen looked like a nylon or plastic insert that is held in by the phillips head screw just in front of the intake.<br /><br />Does this sound right and is that part replacable.<br /><br />pbailey
Dhadley
Re: 1981 Johnson 115 Water Intake Screen Replacement
The plastic screen just "pops" into place. <br /><br />DO NOT REMOVE THAT SCREW!!!!!!
pbailey
THANK YOU Dhadley. :D <br /><br />Looks like my assumption could have led to something, shall we say regretable.<br /><br />pbailey
RKwood
Straight forward change. You may need to break the old one to get it out. <br /><br />I did damage a new one while trying to install it, but that was more due to a lcak of patience.<br /><br />Good luck.<br /><br />RKwood
