1981 90hp evinrude
Brad8769
I just purchased a project boat and need help finding parts. I need the throttle linkage that goes from one carb to the other. Also i need to find the trim assembly. Its the entire trim unit. Any help would be appreciated. The engine model is Model E90TLCIM
boobie
Go to the Top Secret File at the beginning of this forum and look up salvage yards.
emdsapmgr
You might want to start by looking at the original factory exploded parts diagrams. That way you can start out with the original part numbers you are looking for. Check out this factory site: epc.brp.com. A lot of these parts are still available, stashed in dealers across the U.S. Regarding your trim unit/motor. When looking through the 81 parts assembly drawings, you will find that 81 was a transition year for the trim system. During the early part of the model year, the trim motor was a 3-wire motor. Mid-year, OMC changed to the "newer" style which was a 2-wire motor. You will need to know which motor the factory put on your engine- before you go looking for a trim system.
