1980's serial number / harness / general questions
acadian2022
Good morning all. I have a multiple questions regarding a Merc fully restored I just purchased. serial number 6033659 cant find a conclusive year online yet.
Questions.
1. year ? 2. harness is an 8 pin plus 4 wires ( grey = ? ) ( purple = ? ) ( black yellow stripe = ?) ( yellow red stripe = ? ) ( brown stripe blue = ? ) and yellow black stripe.
Assuming red positive and black ground.
external 4 wires blue white stripe and green white stripe I believe is trim up and down and brown white stripe and brown electric choke? I'm not sure if this 1980's has electric choke? one of the previous owners got ride of the dual fuel / oil tank and was mixing directly into one tank and from what I found so far online a specific procedure should be done at the mechanic fuel pump on the engine and seems to me original no bypass of any sort. this engine considering the year would it have sensors for all the gauges I recieved with it? Tachometer / Volts / oil psi / temperature alarm buzzer? I thank all who take the time to help with above questions I'm sure will have a few more :)
The decals are for the 1976 model year.----What HP is this motor ?-----No chokes , as it appears to have an enricher unit.---serial # makes it 1985 for a 175 or 1982 for 200 HP near as I can tell.
acadian2022
Good morning. its a 200HP and was fully restored new paint decal etc that is why it was confusing to me on my end also when looking at picture and couldn't find it by using the serial number. thank you so much all for any info
Dukedog
gray= tach sender wire
purple= switched 12v power
black/yellow= kill circuit
yellow/red= starter circuit
brown/blue= temp gauge
yellow/black= choke/enrichner circuit
these colors stand for all merc wiring i know from at least 1980 up.. they have never changed as for as i know..........
its a 1982 200.............. put a "0" (06033659) as first number for serial number and it should show up on most parts sites....
acadian2022
acadian2022
Thank you thank you... do you have any knowledge about the fuel mix setup they had vs original dual tank? if anything should have been bypassed fuel pump etc properly for me to ensure it was done correctly. I will add a few more question to my original post regarding power trim system.
acadian2022
Questions.
Questions.
Good morning all. when reading some replies my Merc included a cluster of gauges oil PSI / Volts / temp / tac and fuel level. can anyone confirm if this outboard has sensor for oil PSI / Volt fuel I'm aware its seperate. the harness that was included is an 8 pin plus 4 that was confirmed as to what those 4 wires are for thank you once again to all for the valuable feedback
acadian2022
Questions.
Nordin
Decals as racerone says 1976 and also 1977 (decals called "hockey sticks").
But in 1976 and 77 there was no 200Hp, the Black Max was 175Hp those years.
Dukedog
serial number says 200 but picture says either 150 or 175 at most.. has vertical reed front half..
redneck joe
There should be a serial plate inside the towel as well as on the outside , both starboard i believe. Make sure they match.
acadian2022
hi all. you could see the old decal on the hood under paint also 200. the serial tag and the frost plug has the same number as mention on my first post.if this help the heads no is 95081. another question is it possible this engine didn't have an actual temperature sensor reading on line where it should be and there is none nor a plate / plug where one could have been. I just started the engine at the warf and all seems running nicely so far not tested under load mind you. and ouf takes fuel fast :) compared to my previous engine Suzuki DT85 :)
Dukedog
one thing for sure tha motor in tha picture is NOT a 200 with vertical reeds but even MercNet says tha number is a 200??? its either a 150 or 175... if tha year is right ('82) its a 150.. no 175's in '82.... tha over temp sensor should be mounted between 1 and 3 spark plugs by a triangle shaped flat stock piece with holes in tha corners for bolts and one in tha top middle for tha sensor...
acadian2022
Thank you for the feed back I have to say regardless of seeing the old 200 decal under the new decal I can't argue that it's a 200 or not, seen some strange scams in my lifetime.... will check sensor location you suggested and can take as many pictures as need to confirm if this outboard is a whatever HP :) Im always blown away by the members here taken the time to help wow THANK YOU ALL.....
Dukedog
need a picture of tha "clamp tag" and one of tha welsh plug.. look in this area (pic below) for tha build date.. its there but sometimes hard ta see.. will be m/d/yr.. tha one below is a very good stamping (high performance).. thats on tha "block half" at tha base of number two cylinder, kinda behind tha bend in tha timin' arm.. its there, jus hard ta see with some... high perf. date stamp.jpgand a lot better than most that are stamped, especially on production motors
acadian2022
need a picture of tha "clamp tag" and one of tha welsh plug.. look in this area (pic below) for tha build date.. its there but sometimes hard ta see.. will be m/d/yr.. tha one below is a very good stamping (high performance).. thats on tha "block half" at tha base of number two cylinder, kinda behind tha bend in tha timin' arm.. its there, jus hard ta see with some... View attachment 411494and a lot better than most that are stamped, especially on production motors
good morning sorry for the delay added pic will add more today.
Dukedog
but with tha vertical front half thats not possible.. all 200's had a horizontal front half.. really strange unless its had tha front half changed.... although i will add Merc did some strange things with these motors that very few will know 'bout.. sooooooooooooooooooo there's that!
see if you can get a WH number off tha carburetors... will be stamped on tha carb mountin' flange on top... WH ??
it may well be one of tha mythical 200's that very, very few have seen.. myself included.. have heard there was a 2.0 200 built but no one i know has ever laid eyes on one but was like a '78 or '79... jus strange at best............
that motor (first generation) has ALWAYS been a pre-mix motor.. it has no provisions for tha oiler mechanics... 40 or 50 ta one will work for it as for mixture goes... Pennzoil syn blend is great and won't break tha bank....
acadian2022
see if you can get a WH number off tha carburetors... will be stamped on tha mountin' flange on top... WH ??
hi I have the engine up trying to figure out how to remove the single ram to have it repaired one stripped hydraulic fitting at the top and not sure if the ram can be removed without taken the engine off the boat. I started a seperate post for that here are pic of the power trim
Dukedog
should be able ta pull it without removin' tha motor from tha boat.. jus be sure ta pay very close attention on orientation of all tha parts and motor won't collapse on ya when ya pull it off.....
