1980 Mercury 25hp No Spark.
flyingscott
If you have the kill switch in the tiller disconnect that from the switch box see if that gives you spark. If it starts you will have to shut the motor off with the choke. Otherwise my guess would be the switchbox. www.cdielectronics.com has the procedure to test the switch box.
flyingscott
Follow the wires from the tiller one will go to ground and one will go to the switch box. Disconnect the one from the switch box.
