1980 mercury 140 LOUD!!!!
moseslake
is there some material that is safe to put around the cover(inside) to reduce the noise from the motor. i heard of eggshell foam? is this stuff safe, work good? thanks.<br /><br />gary
KYHunter2
Re: 1980 mercury 140 LOUD!!!!
I like 'em loud, that way, no one tries to be a back seat driver ! !<br /> LOL, <br /> "Just Kidding"<br /> KYHunter
cobra 3.0
I'd just be concerned with the flammability of the product and it's resistance to heat from the motor..that being said mine seems to be just plain foam!
Texasmark
Merc put fiberglas blankets wrapped in clear plastic on the inside of the cowlings on later model towers. As I recall my '89 115 had one. <br /><br />After they drastically changed their designs (in '90 as I recall) they used a fiberglass bonnet with glued in foam whereever they could find a place to stick in....on the underside of the cowl.<br /><br />On flammability, some foams are sprayed with chemicals to reduce the possibility. I don't know why you couldn't "contact cement" after a thorough cleaning a layer on the inside of the cowl.<br /><br />There really isn't anything inside generating an open flame and the engines don't have any really hot components, so I wouldn't be too worried about flammability.....I mean like gasoline fumes are all over the inside already, and it runs on gas....how much more flammable can you get....Ok Acetone to name one. Grin.<br /><br />Mark<br /><br />Mark
