1980 Johnson 75 hp Stinger. The tilt trim gauge doesn't move when the motor goes up or down. I removed the wires from the gauge and tested and it moved both ways. I replaced the sending unit that was on the motor as it was bad. I installed the sending unit but the gauge still doesn't move when using the up/down switch. Does the "horn" and purple wire have anything to do with this. Does anyone have a accurate tilt/trim relay box diagram as maybe something isn't wire correctly. The motor goes up and down just fine I just can't get the gauge to work. Does the key need to be on when trying this as well? I have had the key on and it makes no difference. Any help would be great.
