quite a while ago i had a full power over heat on a 1980 Johnson 4.5 (J5RHLCSS) , i put it aside as a "winter project" and am just now getting to it.
i pulled the lower unit and although the pump housing and impeller have seen better days i'm not 100% convinced this was the problem ...or the only problem. The pump intake tract seems to be clear so i hooked up some tubing and squirted water up the water tube that goes into the power head. Water comes out the telltale in the block BUT is was also coming down from inside the housing in the vicinity of the water tube... is that normal??
