1980 Johnson 25HP Outboard - Trouble removing lower end
erikreynolds
Hi Folks,
I recently inherited a 14' aluminum fishing boat with a 25HP Johnson Seahorse outboard that had been sitting (covered) for a few years. I am trying to remove the lower unit so that I can replace the water pump / impeller, but I cannot seem to get the lower unit off for the life of me. According to the parts diagrams I was able to find, there are 4 bolts connecting the lower unit to the upper half as well as 4 bolts connecting the gearbox assembly to the middle "extension" piece. There was also a larger stud / bolt that I removed. It does seem like there is a bit of rust / corrosion on this stud and I am wondering if this is what is holding me up. I did disconnect the shift linkage.
Here is a link to some photos showing the engine ( http://imgur.com/a/kBe1v ). I don't really have much of a budget at all; I'm just trying to restore this old thing as best as I can for my younger brother and I. Model number is J25RCSA. I have rebuild the carburetor, checked compression, and replaced the plugs, so verifying the integrity of the impeller is (I think...) my next step before trying to start.
Thanks for your advice and help!
-Erik
