1980 Evinrude E35ELCSM Water Issue
bwag51w
Have a 1980 E35ELCSM... installed new water pump, cleaned the "pee" tube and nozzle. Still not getting water to circulate. I am using muffs, could that be the issue? Any other items to look at? Thanks for any help.
Honorary Supreme Mariner
You confirmed that the drive pin is in place for impeller.----Yes some motors are shy when on a hose.-----Also a lot of air in pressurized water too !!-----Test on a boat floating it the water is best.----Was there a severe overheat ., yes or no ?----Did you do a compression test ?--Checked torque on head bolts ?-----Perhaps a blown head gasket is the issue.
bwag51w
Honestly don't know a lot about the motor, picked it up for cheap. Compression seems good, drive key was in good when i put the housing back on the lower unit. I can't comment on the overheat, as I just got the motor. Fires up and runs great, just not circulating water. I'll try putting it in the water and go from there...
jasper60103
Make sure the water tube is properly seated in the water pump housing.The grommet can get pinched and block flow.
oldboat1
Muffs would go over the intake under the plate, not the vents on top (just in case that's the issue). Better to operate with the l.u. immersed, as indicated earlier. Lake is best, but can rig a barrel -- water level has to be a few inches above the water pump.
If it's a salt water motor, there may be salt build up in the cooling passages -- would then need to remove the head cover and head to access the passages (scrape them out with a blade). Temp should be 130-140F at the top of the head. 160 is too hot (and too hot to touch, if that's the test.)
[edit. If unable to find a solution, might remove the l.u. and try pushing water up through the tube using a hose (rig fuel hose or similar to fit over water tube). This is done without running the engine.]
Yoslick
My 35 did the same thing, culprit was a frozen open thermostat, had little to no water out the pee hole except when wide open, flows great now..
