1980 9.9 cooling question
Matt Lyons
installed a waterpump rebuild kit because she was'nt peeing. Started peeing after a quick trip in the garbage can, but not very hard. How much water pressure should I expect.
rickdb1boat
Re: 1980 9.9 cooling question
Thats a hard one to answer! If it's peeing good I wouldn't worry too much. After it warms up, feel the head and see if you can hold your hand there for a few seconds. If so, you are all right! At Idle, you should not expect much, but it should be peeing anyway! Make sure you have plenty of water above the pick-ups. Good to have water half way up the leg if you can.
OBJ
lyonsboy....you may try running a wire up the pee hole. A little bit of pluggage will hamper flow.<br /><br />Keep us posted...and welcome to the forums!
Matt Lyons
Outboardjim, the hole and hose are free and clear of obstructions. I am getting a steady stream of water, just not the pressure I expected. Would the impeller fins bent the wrong way cause a lack of pressure? Thanks for the replies gents.
Paul Moir
If the fins were bent the wrong way, they would have straightened when you started it. Reduced pressure may indicate a stuck open or missing thermostat - check your tempurature like rickdb1boat suggested to rule that out.
P.V.
Water-tube grommett!
