1980 70hp evinrude exhuast question
Pacific dory
I have a 1980 70hp evinrude. Last year I replaced the head gasket after noticing lots of steam and water coming out of the two exhaust ports just below the engine head. My problem is this. I just fired up my motor for the first time this season and found water coming from my two exhaust ports with some (not a lot) steam, BUT no exhaust coming from the prop hub like it normally does. Isn't the exhaust for the most part suppose to come out down in the prop area. I'm worried I my head gasket may have blown again. I have check all three plugs and the all look the same, none of them are overly clean like the last time the head gasket went. Also the motor is running great, both at idle, and at power. Thanks for any help.<br /><br />Matt
Hooty
Re: 1980 70hp evinrude exhuast question
Welcome to iboats Matt.
WillyBWright
Where else COULD the exhaust come out? It has to be coming out of the prop. Did you mean that there's no WATER coming out of the prop hub? There should be. Lots of it. You needed a water pump impeller, not a head gasket. Some water and exhaust could come out of the holes, but usually when the motor is in the water.<br /><br />Addendum:<br />Maybe there's an ice or snow blockage in the exhaust cavity in front of the prop. That could do it.
Pacific dory
Yes there is lots of water out of the hub, when I run it on ear muffs. What I'm not getting out of the prop hub is exhaust from the engine while the boat is running. Maybe I'm just paranoind, but I seem to remember bubbles coming up from the prop area in while at idle last year. Right now I'm only getting exhaust and some slight water from the two port holes below the engine head. The tell tale is flowing lots of water and the head feel normal to me definately not hot. I did replace the impeller last season. Thanks for any replies.<br /><br />Matt
WillyBWright
Hootey and I are playing Edit Tag. :D Check out my post above. I added something.<br /><br />On the muffs, exhaust and water should come out of the prop hub. The holes you're talking about are exhaust relief ports and you'll only get water and exhaust coming out of there when the boat is in the water. Maybe a little when it's on the muffs, but that's about all.
papasage
the 2 ports in the back of the motor should have water and some exzoust . mine doesent have much till i put it in the water or a tank . it has a new waterpump kit in it the kit includes thje plate under the water pump . it doesent have much till i increase the rpms of the motor . if it doesent run hot it will be ok . there is nothing rong with the headgasket if it isent misfiring . you may need a water pump . they recomend changing thim atleast every 3 years . if it has ben run without water it is shot . papasage
Pacific dory
Thanks for the response guys. I think I was just paraniod. You know how when your on the water and you hear a different sound, or feel a different vibration. All that stuff makes my hair grey. Especially 10 miles out in the salt chuck.<br /><br />Matt
