1980 40 hp mercury no spark
mastercraft72
Im got this boat off my aunt uncle had a stroke 2 yrs ago and boats been sitting. Got the motor to start for about 6 seconds and wont fire again. Motor turns over but is getting no spark dont know where to start
Texasmark
Might as well start off on the right foot since you are a newbie and we want to welcome you aboard. This site sells parts and we jabber on here to find the broken part and hopefully the folks doin the jabbering buy the parts here. So, since it helps pay the rent I suggest you go to the top of the page here and look in the "Boat Parts & Accessories" tab. Inside look for service manuals and get one. You'll be needing it for lots of things and probably as good a money as you'll ever spend. Seloc is the name and you can buy the manual outright or rent time online which is immediate after you slide your card and you are good to go immediately. I used OEM and these and I like these better because they define processes better and have more pictures.
You don't have to buy your parts here but they have a goodly supply of quality parts at a reasonable price. Service after the sale is great too. I buy parts here and have had to use their service in replacing a bow for a Bimini Top that was smashed at the factory somehow......bow was smashed, shipping box was untouched. Had a full replacement in 2 days.
Whether you buy anything or not it doesn't affect your surfing nor the quality of your answers. We're here to help each other but if you aren't familiar with things in the conversation, it sure helps to have a reference source handy so that the info you get makes some kind of sense.
The manual is really a good idea because after you get your ignition problem solved, you will be into your carbs and then your water pump and then timing-carb synchronization, and then shift and throttle linkage, and on and on. I was going to jump right in and attempt to answer your question but I saw you are new to the forum and I am not famliar with your engine. What I may have said may have done more to confuse you than do you any good.
HTH,
Mark
Chavi
Mastercraft72,
Welcome to the forum. I am also new as a registered member but had been reading the posts for at least a couple of years before creating an account (procrastinator I guess). When I first started visiting the site it was for the exact same problem you are having. I have a 1982 Merc 40 hp. It is also known as the 402 (40hp 2 cylinder). I read it somewhere in this forum that it may be the stator and the power pack. I contacted a guy named James Foster who works for SouthCentral Outboards located in the Chicago area (I may be wrong) and he assisted me right away. I do not have his phone number anymore but the email address if it has not been changed is outboardsanonymous@gmail.com He sold me several things that he believed were the problem and even instructed me on how to install them (removing the flywheel etc etc). I bought the Stator and Switch and also purchased the wiring harness which I never even installed cause the Stator and the switch did the trick. I felt that the fact that guy walked me through the repair by phone saved me so much money that he deserved the sale of the wiring harness and it may be needed in the future anyways. I spent about $250 on parts (used parts) but the fact that he gave the knowledge on the repair has made me lose the fear in repairing and replacing anything on the outboards. Try to contact him and hopefully he can assist you the same way he helped me.
Good luck and hope to hear you got it fixed.
Chavi.
