FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
First get a manual.<br />If you want to do it woithout a manuel good luck.<br />You will need to disconnect the Shift mecanism above the lower unit. Might have a friend move the shifter to see it.<br />Take off the prop.<br />Then take off the bottom by the 6 bolts. there is a hidden bolt in the exhaust snout on the rear of the lower unit behind the prop.<br />Should drop out. <br />The pump assembly is on top of the lower unit.<br />Remove each bolt and such and then replace in reverse order.<br />Did I mention get a Manual ?
I've been using my digital camera to take pics of everything I do on my engine and boat. Getting old and the memory isn't like it used to be. And the pics in those manuals are terrible.
