1979 johnson 100 hp tilt and trim question
mot007us
How do I put hydraulic fluid in my tilt and trim also what type of hydraulic fluid do I use, also, I have a black switch on the tilt and trim and I want to know what it is. I hope someone can help me. Thank you p.s. I hit a rock last night.:faint2:
boobie
Raise it to the full tilt position, Remove the fill plug and top it off with Dextron II. Then cycle it up and down 10 times checking the fluid level while doing this. Post a pic of your black switch.
Joe Reeves
Yeah... what Boobie said.... BUT.... put that screw plug back in before you drop/raise the engine, otherwise you'll have fluid shooting all over the place.
mot007us
Thank you for your answers, but I can't post a pic., I don't have a smart phone, ha ha, I am going to do what you suggested with the fluid, I will keep you updated.;)
interalian
Best way to fill is using a 20-30cc syringe (vet/farm supply), and attach a length of thin tubing to the tip. Draw fluid from the bottle and inject.
mot007us
Thank you, for your replies, I finally figured all out, and it seems to be working. :joyous:
