1979 evinrude 70 sluggish after 10 minutes
Mudflap33
Already ruled out fuel and electronics, 10 minutes in drops to half power, stop put it in reverse , full throttle for 1 second, then runs fine again whats wrong also on muffs exhaust is through foot no exhaust through mid section, when hot no exhaust through foot, what gives or is this normal
StarTed
Could you be getting water in from your exhaust manifold? Check your spark plugs for water.
Really I have no idea but just a thought.
emdsapmgr
Any chance you are getting surface weeds wrapped around the prop? Reversing prop thrust certainly cleans them off.
Mudflap33
Ok a friend just told me the throttle cable also controls the advance on the engine. .meaning as you give more throttle the engine otor advances more is this correct
Mudflap33
Good thoughts on prop but 40 ft of water..also is there some water diversion flaps in the mid section or lower unit
interalian
Yes, moving throttle forward increases timing advance as it opens the carb butterflies. Direct mechanical timing advance only on these.
interalian
There are small baffles near the exhaust relief ports high on the leg. At idle in the lake, most exhaust will go through these along with a mist of water. At higher running speeds the majority of the exhaust will exit underwater through the prop hub. When idling on muffs, the exhaust will come through the prop hub as there is no backpressure.
interalian
Next time you lose power, try pumping the primer ball. You might have a weak fuel pump.
interalian
Ok iterilian what would be the most common failure..cable? Sensor?
Not sure what your question is. I'm suggesting the pulse fuel pump is a bit weak and after running for a while can't keep up with demand. Pumping the primer ball will refill the carb bowls if you're running short on fuel and prove weakness in the fuel pump, or perhaps a leak somewhere in the lines.
