navillus11
- Oct 9, 2011
- 4
Hey everyone I am new to boating and this website, I purchased a 1978 MFG Caprice with an OMC 140 engine in it. I had it looked over at the marina near my house and he told me it needed a new timing chain and gear set he said it was stretched from age and that it was jumping timing, He also stated it was running on 2 cylinders (inline 4). He performed a compression test and all 4 cylinders read compression of 130 PSI. I was talking to a mechanic friend of mine and he said if the timing chain was truly jumping timing that the compression on 2 of the cylinders would be less due to the timing being off. I have not had enough experience with boats to know who to believe, I don't mind spending the money ($400ish) but I want to know for sure that's the problem. When I was performing the winterization 2 weeks ago I heard a slight noise that could have been the chain hitting the cover... It idles pretty smooth, When I would first start it the engine would idle rough I would increase throttle to about 1000 and it would smooth out, then bring throttle back to 600 it would idle fine. Any advice would be greatly appreciated!!!
Thanks for your time!
