1978 mercruiser 165 won’t time
Starcraft4me
Have a 78 Starcraft American 18 with in-line 6 (Chevy). Verified #1 cylinder is at exact TDC on compression stroke and rotar is pointing directly at #1 cylinder. Harmonic balancer has been rebuilt and mark is at exact zero when at TDC. Carbs been rebuilt. Engine fires right up and runs very good BUT when I put a timing light (new timing light) on the balancer it’s at approximately 14-18 ATDC. Engine is very snappy but isn’t even close to correct timing mark. Supposed to be 6BTDC. Points are set per manual. Engine won’t run at 6 BTDC. WHAT AM I MISSING HERE????
Bt Doctur
The rotor points to #1 wire in the cap/ If you say your pointing to #1 cylinder it may not be #1 wire
achris
More fish than mountain goat
How did you verify that the crankshaft is exactly at TDC?
Chris....
