Re: 1978? merc black max fuel/oil ratio and more
Run your new beast on premium unleaded (not sure what they call it in the US, I think it's called Hi Test??). Over here its basically 98+ octane. Regular unleaded is too low grade for an older engine although the octane ratings are different between the US and Australia.<br /><br />For oil, use Quiksilver 2 stroke (cycle) oil. It is currently rated as the best oil on the market. For gear oil use the Merc lube or if you want to get carried away with yourself use the premium lube (the MerCruiser stuff). In reality the difference between the two is the premium stuff probably has a better ability to mix well with water as water ingress on a sterndrive (probably a moored boat) is obviously much more of an issue than a trailered boat.<br />Off the top of my head I would say the plugs are going to be BUHW or BUHX, both being surface gapped, cool running plugs.<br />The early Merc V6's were not paricularly known as good engines. They had serious issues with corrosion of the block. If its a freshwater engine then no problem, but if its a salty then its something to consider.<br />One thing I must say, and I can't help myself, is that nothing and I MEAN NOTHING, sounds quite like a V6 Merc....<br />Cheers
