1978 Evinrude 55 with a broken crankcase
douglasslloyd
I am seeking to find out what model and year Johnson or Evinrude motors would be compatible with this motor. This engine is a short shaft model. My hope is to use the "bottom end" of this motor with the "top end" of a similar hp motor. Does anyone know the range of years and hp that could "bolt on" to the lower part of my motor.
rolmops
I believe that it is from '76 to 88.The 50,55,60 and 65 all used that crankcase
douglasslloyd
The motor is a 1976 model not a 78. I have a line on a Johnson 48, 1987 model spl. Any idea if that might fit to the bottom end of my motor?
bonz_d
Should work but check the gasket part number between the crankcase and exhaust. Crankshaft should have the same splines as the old one.
