I don't think fuel lines will be the solution, although obviously wouldn't hurt to replace them if they're old. I would do or redo the link and sync procedure first (check stickies for your engine), suggested in #2, then do the drop test that boobie suggested. Beyond that, you could have incorrect carb reassembly (remove and check) and setting. Could have a broken reed, although probably not the most likely cause.
