1978 evinrude 140 hp cranking over hard
harmons
My 1978 evinrude 140 will not crank over hard enough to fire. If I remove the plugs to remove the load, it seems to crank over with plenty of power. Put them back in and it cranks over very slow, is this a bad starter or potentially bigger motor issues?
harmons
Should have said, I've tried different batteries that are fully charged
ondarvr
Jump from the battery right to the starter, if that doesn't help pull the starter apart and see if it has problems.
Honorary Supreme Mariner
It is very easy to take the starter apart for inspection and costs no money !!------Go ahead and do that.---Ask for further help once it is apart.----Note----only about 1 in 10 folks will actually take the starter apart.
harmons
I'll give that a try tomorrow. Any pointers on what to look for?
Worn out brushes.-----Take a digital meter and take an ohm reading from where brushes contact ( commutator ) to the shaft.-Should read infinity.
