Kevinhand26@
Thread starter- Joined
- Jun 18, 2016
- 8
Just bought motor guy said motor had set up for five years and needs carbs cleaned. It has 115-121 compression and I have spark at all 4 plugs. I bought
carb kits they did not come with new floats. I sprayed them good with carb cleaner then blew everything out with an air hose but I really don't know much about carbs i did replace the float needles. Crank and ran fine in the yard but when I put it in the water it would idle around but give it a little throttle and it cuts off untill it does not crank anymore and starts turning over sluggish and I seen a lot of fuel in the water. I don't really know the cause. Where do I go from here.
