fishinrado
Thread starter- Joined
- Nov 8, 2006
- 137
hello all, restoring an older 16' crestliner (can't find year , any good resourses? - think it's a 74 due to the blue and red trim colors )
v-hull with the above engine. posted some threads last fall and now have the boat on the water. engine seems to run fine except for the following :
power trim goes up and down but when taking off with trim up it goes right back down by itself. i know there is an adjustment screw but is there a way to check the fluid in the power trim unit ? in reverse the engine bounces up and down and won't hold the postion. it just pops out of the water, why? installed new throttle and shift cables. they work great in the driveway while the motor is off but at the lake (once engine is warm) they catch each other after full throttle and then you can't move the lever back unless you manually slip a screwdriver in between the cables to help them ride over each other's holding clips. will post pics on next thread........ thanks all!
