Hello,
Last year I picked up a 1978 Crestliner Muskie with a 1978 55hp Evinrude outboard. I have worked to get the boat "water ready" - new flooring, new seats, new lights/wiring. I have also been working on getting the motor to run properly. I have purchased a manual and referencing it frequently. I have rebuilt the carbs, replaced fuel pump, lines, and some wiring on the motor itself (disintegrating). The motor starts (almost every time), idles well, and runs on the water (finally) - my problem now is that when we took the boat out last weekend, the best speed we could get is 5-6 knots. When in warm-up idle, the engine seems to jump up to a really high idle (i lower the warmup lever and it calms right down), when the boat is in gear (in the water) the sound of the engine at WOT does not seem to be getting up as high as when the warmup throttle is opened fully. is the motor just under powered for the boat or am i missing something. I have not had a compression test done, but know that both of the cylinders are working (have unplugged both spark plugs and the the engine continues to run (rough, but it runs).
