1978 35hp Evinrude head gasket issue
Dean1515
Hi all......first off, this is not my first boat, nor is the first time I've worked on engines, but this is the first outboard I've ever worked on. It's a 78 35hp evinrude and the first time I went to fire it up, I knew it had some problems. Here is a list of what I've already done....
1- installed new impeller kit
2- new exhaust cover gasket
3- replaced both ignition coils( old ones look like they were half melted)
4- new thermostat , seal , seal retainer and spring.
5- new head gasket
6- new spark plugs
7- re synced the ignition and carb
8- new solenoid
I got it all back together yesterday and it fired right up, something it's never done, ran great for about 2 minutes then it started to miss a little, then I noticed water coming from the top of the head gasket. Yes I did Torque the head in 3 steps to 192 inch lbs. and I'm sure the miss is from water getting into the #1
cylinder. So now my concern becomes a warped head or worse, a crack. My neighbor said to maybe use a sealer on the head gasket, but I've replaced many head gaskets and never had to do this. Is there some weird cork about these outboard that would justify using a sealer? I'm just hoping that you guys out there with alot more experience in these outboards can lead me in the correct direction....thanks
Every cylinder head I have looked at has been warped.----Yours is no exception.----Should have been trued up before the new gasket install.
F_R
Reading between the lines, it has been overheated, hasn't it? Too common on those motors. Yep that will warp the parts.
