maverick600
Thread starter- Joined
- Apr 16, 2016
- 4
Hello all,
I am new here to the site and have been looking around some before I decided to ask the question. There are some helpful links and posts here for sure. I just purchased a 14 Grumman boat that has a 77 25hp on it and it seems to run pretty damn good but I havent really owned a motor this little before, the only johnsons I have owned have been 150 and 200 that is on my hydra-sport now. While running the engine in a barrel I have noticed that exhaust was coming out between where the lower unit and the housing bolt to each other, I am hoping this is normal since the exhaust does not come out of the prop like the engines I am used to. I also noticed that it doesn't pee very well when it first cranks but after awhile it starts flowing better. While at the fire station tomorrow I plan on pulling the lower unit and doing an inspection along with changing the foot oil but wanted to get some advice first. I dont think the tube is clogged since I did see water flowing through it but not sure if I have a weak impeller or water doesn't flow as well in the older engines as they do in the newer. Any other tips and advice would be greatly appreciated.
