If you ain't first you're last
Thread starter- Joined
- Oct 11, 2018
- 13
Installed new tilt and trim motor and can't seem to get the trim unit to go down. Seems to be building pressure or something. If I losses the release valve it will lower fine. Tighten it back up and it goes up great. As soon as I start going down again it looks like it tries but won't unless I open the release valve again. I've skipped all the relays and junk and have the three wire a going from the trim motor to the battery. Ground and up or down. Any help would he great! Thanks guys
