1977 johnson 140 hydrol. lift.
kickback
worked one week ago. then stopped. no movement. Are there fuses for the lift??
ICEMAN
Re: 1977 johnson 140 hydrol. lift.
HI, when you operate the tilt unit, does it work in the down mode, but not up? The fuse is located in the tilt wiring junction box. If it works in the down mode, suspect the tilt solenoid is bad, the solenoid is only in the up mode on the unit.
