1977 evinrude backfires while at idle .
eripresto
I have a 1977 Evinrude 115 , hasn't ran in 5yrs. rebuilt carbs , got it started but it backfires at idle . checked the coils, found a bad one , replaced with a known good one , and it still backfires . found the bracket that holds the coils was broke I don't know if that has any thing to do with it since the ground wire of each coil is bolted to it . any help would be great . thank you .
F_R
Honorary Supreme Mariner
Are you sure it is a backfire (bang through the exhaust)? Or is it more like a muffled sneeze? The latter is caused by running too lean (not enough fuel or too much air).
eripresto
yes its bang through the exhaust , what jets do I change (the ones behind the screws on side of carbs) ?
