1977 Evinrude 175 V6 fuel problem
Gizzymark
In 1986 I bought a 19 foot boat with this engine and rebuilt it. It ran great until 2013 and would not start. It not getting fuel to the engine.
Replaced:
Both fuel pumps
Fuel filter
Hoses
Drained the old gas and replaced it
Squeeze bulb
Should I check fuel pressure at the carbs? I took the cover off the carbs and they looked very clean.
Is there a brass filter on each carb? Any ideas on what to check? The marina nearby charges crazy labor rates, so any ideas would be helpful.
boobie
Squirt some premix fuel in the carb throats and see if it starts. If it does you need carb work.
emdsapmgr
What makes you think you are not getting fuel to the engine? Are the plugs dry when you choke and crank over the engine? You need to determine if any fuel is getting through the system at all. For instance, if you prime the fuel hose bulb, do you get fuel to the first fuel pump? Next, if you prime the fuel hose bulb, do you get fuel to all 3 carbs. (you can pull the drain screw off each carb bowl to see if the fuel is flowing into the bowls while you are priming the bulb. If so, crank over the engine while choking it. When you do that- do the plugs show signs of wetness? (from the fuel flowing thru the carbs.) Was any fuel left in the carb bowls when it was put up for the winter? Sometimes this fuel will dry up-leaving the dried fuel gel in the passages-which can restrict fuel flow.
Gizzymark
If I spray gas/oil mixture in the carbs it starts for 7 seconds, then quits. Fuel bulb is hard, gas is getting to the first pump.
Ignition is good, it fires right away when spraying gas into the carbs. I see no drain on the carbs to find evidence is gas is getting there. Every year when putting it away for the winter I did the following: start engine and disconnect the fuel hose, let it run until it runs out of gas. I did this for 25 years and this procedure worked fine.
Gizzymark
I need to determine if fuel is getting past the fuel pumps and into the carbs. Then I must determine if it's a carb problem.
Heard that proper fuel PSI is 2.5 between the pump and carbs? I popped the top off one of the carbs and it looked very clean. Maybe an air bleed is clogged?
Gizzymark
Could a bad reed valve cause lack of vacuum in the crankcase and then a lack of fuel pressure? I need a 1,2,3 inspection procedure on what to check next after new fuel pumps are installed. Both of mY engine manuals are rather vague.
Mark
boobie
Remove the plugs on the bottom of the float bowls on the carbs. There should be 6. Then pump your primer bulb and see if you get any fuel out of them.. If you don't , you could have needle and seat problems. If you do and it still won't start the high speed jets below the plugs may be clogged.
Gizzymark
Boobie, you have the most relavant response and seem very knowledgeable, thank you.
I pulled the drain plug out of the top carb (found it!) and drained the gas out. It dribbled a little bit of gas out (not a lot)
Pumped the bulb and gas was defiantly coming out the drain plug hole. I mentioned before that there was some old gas in the system. Drained the tank.
The gas draining out of the carb was a little stinky, not too bad. Probably a mix of old and fresh gas.
Rebuild the carbs? Drain the gas out and try it again? I value your opinion.
thanks, Mark
Gizzymark
My idea is to pull all the drain plugs out on the carbs. Pump the bulb until the fresh gas flows out. Try to fire the beast again. If not successful, pull the carbs and rebuild them. I have a friend who has a vibratory cleaning tank. Disassemble and clean the carbs. Whatcha think?
emdsapmgr
You are headed in the right direction. Keep in mind that if you decide to clean the carbs, that just cleaning the visible surfaces may not be enough. You need a cleaner that will dissolve dried fuel-esp if it's blocking a small passage in the upper carb body- that's not visible.
emdsapmgr
Probably best to get all the fuel out of the tank and start with fresh fuel. No point in putting new gas into a tank of old fuel. You could have a layer of water on the bottom of the tank. And that's the first fuel sucked up by the fuel pickup.
Gizzymark
Fresh fuel, but there was some old gas flowing in the carbs before draining the tank. One carb at a time, I removed the drain at the bottom and pumped the bulb. New fuel flowed through the system and drained out. One of the carbs had no or little fuel flow. I think the float is stuck closed. AHA! I removed all 3 carbs, and in the process of cleaning and rebuilding them. To be continued...
emdsapmgr
Good thinking-good test. Will be interesting to see what is inside the fuel bowls. Do a check. If that engine has any old, original fuel hose-it's not ethanol compliant. You may find a lot of black bits of hose inside the carbs.
boobie
When you have the carbs off, make sure you check the high speed jets in the float bowls.
