1977 70 hp johnson
ashion
A weak starter prevented my motor from sparking. Once i figured that out, i figured out spark plug 2 isnt sparking because of a bad power pack. I was told it wouldnt do much damage to run the motor off just 2 coils/cylinders/spark plug. Is that true or false? I do not want to do any further damage to the motor, I just need it to run for one weekend and I can get the power pack.
flyingscott
I wouldn't do it just because if it is actually an intermittant spark. The motor could end up misfiring and that will cause damage.
emdsapmgr
If the carb that feeds the dead cylinder is still pumping fuel/oil into that cylinder every stroke-that would mean that the cyl is getting lubrication. At that point, I doubt you'd damage it much. (I'd probably verify to be sure that is happening....) Only problem will be that the engine won't make much hp and it will burn a lot more fuel as you crank up the throttle to make even some hp- the bad cyl will just be pumping unburned fuel/oil down the exhaust pipe. Just seems like an exercise in futility..
