1977 25 hp evnirude
tdr9499
motor has not been ran for almost 4 years. i replaced the impeller, fuel pump, for rebuilt carb. boat runs good for about 10 to 15 minutes then dies out like it runs out of gas. it will crank back up and run fine. i am wondering if the motor is overheating. is there a therostat on the motor that might be bad. thanks for any info. boat also smokes real bad. I think the mixture of oil and gas is wrong.
rwise
Re: 1977 25 hp evnirude
tdr<br />first try something simple, is the vent on the gas cap open? If not this could cause the dieing out problem. post the modle number of your engine, it will help the ones that can help you! gas:eek:il 50:1<br />Richard
D
DJ
Guest
tdr9499,<br /><br />rwise gives good advice. When it dies, do you have spark?
