* 1976ish Merc 115 6 cyl 2 stroke. tilt issues. where do i refill the tilt oil? *
IDG4EVER
hello all. i am new to the boating thing. i just got a 1974 glastron 18' swinger tri hull.
the boat has a pretty healthy merc 115hp motor with power tilt and trim.
my question concerns where and how i am supposed to refill the tilt oil. is there some kind of reservoir? i looked and couldn't find a fill location. the tilt went down fine but didn't want to come up. i am assuming that i just need fluid.
thanks for any feedback you are willing to offer.. thanks
Chris1956
Re: * 1976ish Merc 115 6 cyl 2 stroke. tilt issues. where do i refill the tilt oil? *
That motor should have a tilt pump and control valve installed in the boat. The fill is an aluminum straight slot screw on the right top of the resvoir. Use 5W-30 motor oil to top it off. The pump motor spins one way to trim up and the other way to trim down. There is a single trim solenoid on the pump assembly for the the up direction. If the motor will not run in the up direction, check the solenoid for power and proper operation.
IDG4EVER
thanks much. i guess i didnt see the letters F-I-L-L or V-E-N-T. hahaha.. well thanks. it is working great now.\\
Now i have to deal with the steering issues. the other day i drove the boat using ropes..
