This motor will not top out at high end without cutting out. It has great compression on all 6 cyl. We replaced the carbs, switchbox, trigger, stator, rectifier, plugs, coil, and all wires. Fuel system and water pump works fine. The timing is dialed in. It starts with no problem. Someone mentioned the secondary timing needs to be adjusted but they don't have the equipment to do it. We are at wits end on this thing. Does anyone know what needs to be done with this motor aside from sinking it? Thank you for any help.
