Greetings from Australia.
I've been tasked with returning my elderly father in law's boat to a going concern, he has owned it from new, 105 hours of fresh water use only. It has not been used for the past six seasons, marine mechanics around here aren't real interested, too old to bother with.
Engine starts and seems to run OK until throttle is opened to the point where ignition and throttle advance engages, then just bogs down.
Engine serial # is : 4368089
So far I've discovered:
Majority of engine wiring is perished
Battery is not charging
Tachometer is erratic
There is evidence of rubbing on the stator plastic covering and some of the flywheel magnets.
Given the components are 40 years old, I'm thinking my best option may be to just replace the engine harness, stator, trigger, switch box, and rectifier, I'll need to order from the US. I have not been able to source the ground or ignition harnesses.
Does this sound like a sound strategy?
I'm concerned about the stator rubbing, any tips would be very much appreciated.
Cheers
Reg
Cheers
Reg
