1976 Mercury 115hp Trim / Tilt ????
bren7176
I have a 1976 115 Hp, found a trim tilt unit wondering if this will fit .. It from a Mercury 1500XS..
thanks
Brendan
Chris1956
It will depend on the year of the 1500XS. If 70s thru early 80s it should fit. You will want the two trim cylinders, two trim brackets, 4 hydraulic hoses, the trim pump/reservoir and the 3 button trim panel.
Faztbullet
The 1500XS was only made 3 years(76-78) and used the same trim unit as all the inlines with remote pump...
