1976 johnson 85hp water pump question
henry519
i have a 1976 johnson 85hp.after removing the water pump the impeller was basically ground up chunks so im rebuilding the water pump i couldnt get a new case just everything else. is there anything special i need to know before completing this task???
Walker
Re: 1976 johnson 85hp water pump question
Yes, you need to be sure no chunks of rubber got up into the engines cooling system.
henry519
would i do this by flushing the system?
henry519
is flushing it out with a garden hose sufficient??
