1976 Johnson 115 Lower Unit - reverse only
sonaros
While running my boat, it seemed like the prop spun out while in forward gear. I put the boat in neutral, then tried to go forward again. The engine accelerated, but the prop did not go forward. I tried reverse, which worked, but then I could not get it out of gear. I opened the command center, and everything looked fine. I even tried to manually shift forward, but could not. I took it to a shop prior to putting it in the water (it had sat for 2 years) and asked them to check everything out, but when I drained the lower unit, very little lubricant came out. They failed to check the fluid level. Any help diagnosing and/or resolving this problem would be appreciated.
