1976 9.9 eska clogged water pump
joe carpenter
I have a 1976 9.9 eska with a clogged water pump that I planned to use for fishing tomorrow:( I think it is clogged from the last time I used it in a heavily weedy area. How do I unplug it:confused:????? Please help!!!! I also need a service manual for it
joe carpenter
Re: 1976 9.9 eska clogged water pump
Took the lower unit off found some sand or debre in the pump housing. blew air into water line going to the engine. I think the blockage is in the water in the engine:eek: Without a manual I don't know what Cover to take off on the engine. Any suggestions on how to return the water flow through the block:confused:
kodibass
Master Chief Petty Officer
Go to youtube watch the video on eska waterpump repair, its pretty good, It may answer your question,
KB
joe carpenter
Thanks for the input... I'll try that I hope it shows how to restore water flow through the engine block, because that's where I think the blockage is. Do you have a link for that video?
