1976 85 hp evinrude ignition problem
Bass_brostv
I recently bought a 76 raycraft with an 1976 85 hp evinrude. Here's what we've done. The solenoid was bad so replaced that then battery was to low to engage the starter so bought a new battery now when you jump across the solenoid the starter fires up and motor will try and start that way but now when you turn the key nothing happens. When before when you turned the key you could flip the electric choke switch and that would work and the the solenoid or starter would click but now when you turn the key nothing happens and I've checked the fuse and it is fine and idk why there is no power to the fuse or the ignition switch any input would be greatly appreciated.
gm280
:welcome: aboard Bass_brostv. Glad to have you as a new member her on iboats...
I read the comment and the first thing I would say is, do you own a meter and know how to use it? If so this is going to be easy to fix. If not, then it is going to be a little more effort.
If you have a meter, test to see when you turn the ignition key to the start position, you have voltage at one of the solenoid's small terminals. One small terminal will be from the key ignition switch and the other small terminal will either be going to a ground terminal or a neutral safety switch. So you have to have the engine in neutral first of all. If you don't have voltage at the small terminal when you turn the key, you have a problem with the ignition switch or the wiring to and from that switch. If you do have voltage at the small terminal of the solenoid then you either have no ground on the other small terminal or the safety switch is either not in the neutral position or it is bad or the wiring is bad. So once you tested those things, you should have a good idea of your problem. JMHO
One thing you do need to do either way , is remove the ground wire terminals on the on the engine and clean them to bright shiny metal and reconnect. A lot of issues are due to the ground wires being neglected.
F_R
Honorary Supreme Mariner
No Title
An outboard mechanic that knows what he is doing could diagnose that thing in about 5 minutes. He would not guess, he would test. You can do it too, if you have a multimeter and know how to use it and have a wiring diagram, and understand electrical circuits. Perhaps you have a friend that can help you?
Well, anyway, I don't have the diagram for your 85, but here is the one for the 70-75hp. The portion that you are interested in should be the same.
If I were to guess, the fact that you replaced the solenoid raises flags. Did you use the correct one, or did you get something at the Auto Parts store? OK, you replaced the battery so the battery terminals should be clean enough. But how about the terminals on the ends of the battery cables? Clean them shiny bright with some sandpaper or similar.
Bass_brostv
The solenoid I replaced came of of an identical 85 hp evinrude donar motor. But everything on that end is fine. I do understand electrical circuits and know how to use a multi meter thank y'all for the input. I just did not understand how there was power to the fuse and then now there's not but I now know what to look for and how to tell what the readings with the multi meter actually mean and where to go from there. I will keep y'all updated as to how it goes again thank you and any more input would be greatly appreciated
