1976 55 hp johnson seahorse has no spark help needed
Joe Reeves
Re: 1976 55 hp johnson seahorse has no spark help needed
Remove spark plugs... disconnect the large main electrical plug at the engine... crank engine by jumping starter solenoid and observe the spark.
If you now have spark with that electrical plug disconnected but none with it connected, replace the ignition switch.
If still no spark, the cause is usually a blown powerpack.
