1976? 40hp shift
Buster1955
I am looking to buy a boat with a 40hp Mercury 402, but the shifter will not go in to neutral,how do I fix this?
Buster1955
Maybe I did not post this right,I am looking to buy a boat that has I think a 1976 Mercury 40hp,402 model,the shifter on the control box will not go in to neutral ,what causes that and how do I fix it. Thanks buster1955
Buster1955
I am not a new boat owner,but someone just totaled my boat ,rear ended me. I am looking at another boat, and the control Handel will not go into neutral as I said how can I tell if it is a problem with the control box or something in the lower unit ?
roscoe
Will the control handle move at all?
Stuck in forward?
Disconnect cables from engine end.
Try shifting.
Then try to shift engine linkage manually.
Then check the cables themselves. Could be split/cracked, rusted.
Texasmark
Stuck in forward?
Try shifting.
+1..........
Buster1955
Decide not to by the boats,to many problems, no registration for the trailer and Motor V can not garantee I can get one.Thanks
