1975 Mercury 9.8 Ho hard to start
shane e p
Hello. Compressions test top 125psi. Bottom 115psi but still difficult to start. New plug. The right one. Fresh full mixture..
once started run well. It's just starting from cold? What can I try next? Thank you.
tpenfield
Using the choke? Choke actually working?
Prime the fuel bulb?
How many pull does it typically take?
shane e p
Yes using choke,,it is working and closing fully..using the priming bulb until it goes solid. I can hear the fuel moving when priming. 10 pulls and sometimes not even then. If I remove cover and give squirt of easy start off it goes straight away?
