1975 Mercury 1500 - runs for 15 minutes and dies
Tiz
I inherited boat with a Merc 1500 outboard. She starts fine but after about 12 - 15 minutes, it dies. It's not a fuel issue because I hooked up an external tank and she still does the same thing. It doesn't matter if I'm idling or going fast, it's almost as if the key is being turned off. Once it dies, it'll turn over but not catch. Could this be an overheating issue? It seems to pee well. I'm thinking it's a coil or the switchbox but these are just guesses. Does anyone have any similar experience? Thanks in advance.
Faztbullet
Make sure mercury tilt switch is disconnected and if it is try a jumper from red to white on switchbox. If it still dies its the trigger..
