1975 Johnson 85hp Compression Check???????
springer9861
Hi All,<br /> I went and looked at a used 16 boat tonight and I also took a compression check on the motor. The motor is a 1975 Johnson 85hp, it had #110 on all four cyclinders. Is this good for this old of a motor? The guy selling the boat said that the motor had been rebuilt in 1995 because his friend tried to adj. the carbs and that burnt a hole in one of the pistons. The rest of the boat looked good, it's a 92 yar-craft and he wants $3000.00 for it.... Thanks for any and all info!!!!!!!!!!!!! Larry :confused:
Fouled Plug
Ensign
Re: 1975 Johnson 85hp Compression Check???????
Can't really say on the boat, but the compression on the motor isn't too shabby. I would try decarbing it if you decide to buy and see if you don't get a few more #'s of pressure. How was the lower unit oil? Did you get a test drive of the boat yet?
springer9861
Fouled Plug,<br /> I didn't check the lower unit oil. What do I need to look for? The guy selling the boat said we could take it out anytime I wanted to. Thanks for the reply...... Larry
Fouled Plug
Ensign
Look for metal shavings, water in lube. New lube is sometimes added just before sale to mask seal probs or other nasties. A test run should last a while and cover all ranges of RPM's and several stop/start cycles. Check the lube again after the run.
