http://www.boats.net/parts/search/BRP/JOHNSON/1975/85ESL75E/EXHAUST HOUSING/parts.html
I have a 1975 Johnson 85 hp outboard motor. In order to manually tilt the motor up and down you flip a small lever which releases a mechanism allowing it to tilt up or down. Recently the manual tilt mechanism stopped working, I am no longer able to tilt the motor up, and it is stuck in the down position. The lever that usually has some resistance and spring to it, no longer does and is loosely hanging. I was wondering if anyone has any experience with this, knows what the problem is and how I can fix it. Here is a link to schematic of the tilting mechanism and also the only picture I have of the style of tilt. I appreciate any help or insight anyone can offer. Thanks!
http://www.**********/parts/search/BR...ING/parts.html
